Overheating after engine froze due to a weather freeze
120,000 MILES • 3.1L • V8 • AUTOMATIC
AIDA RAMOS
With a freeze my car's engine froze. i got it to thaw heated change water pump still heats up could it be the radiator? Overheating was caused by a weather freeze.
Dec 25, 2016 at 7:40 AM
STEVE W.
  • 15,414 POSTS
If it thawed out the problem is not likely to be the radiator, when those freeze they break and leak. Rent a pressure tester and see if the cooling system will hold pressure. If it holds pressure the issue could be a failed thermostat that is not opening.
If it fails to hold pressure it is something like a head gasket.
Dec 25, 2016 at 8:46 AM
