OVERHEAT
276,000 MILES • 4 CYL • TURBO • RWD • AUTOMATIC
ASWAN MOHAMED
I keep a dual action from that time my radiator water level always low .no leak at all so I change water pump, gaskets, now radiator hose always blows. Much bobble coming I past a head gaskets now what can I do for it?
Jul 21, 2016 at 12:23 AM
HMAC300
  • 48,601 POSTS
have it pressure checked for leaks to see if it is a head gasket. recheck your work it may be leaking compression into cooling system. it also may be the wrong water pump that goes in wrong direction.
Jul 21, 2016 at 2:47 AM
