Overheating
179,850 MILES • 2.3L • 4 CYL • TURBO • 2WD • AUTOMATIC
TADRIAN712
  • 5 POSTS
Changed thermostat, water pump, radiator, checked hoses, checked fans they work fine and changed temperature sensor twice and car still overheats.
Dec 23, 2021 at 10:44 PM
  • 110,248 POSTS
You changed nearly everything. I have a couple of questions. When you reinstalled the coolant, are you sure all air was out from the system? Also, when it overheats, do you hear coolant boiling or spilling over indicating it isn't a wiring issue with the sensor?
Also, keep in mind that a failed head gasket can cause this type of issue as well. Take a look through this link and let me know if anything mirrors what you are seeing:
A few more questions. Does the vehicle feel as though it has a power loss? Are there any odd sounds or odors? Any smoke from the exhaust?
Dec 24, 2021 at 10:10 AM
TADRIAN712
  • 5 POSTS
Yes, I get white smoke when parked and revving at 3,500 RPMs.
Dec 24, 2021 at 12:20 PM
  • 110,248 POSTS
Okay, that could indicate a bad head gasket. Does the engine coolant ever seem to get low and require you to add? If so, the next thing I would do is check engine compression to see if we have one or more cylinders with lower compression.
Here is a link that shows how that's done:
Also, if you could record the white smoke so I could see it, I may be able to tell what is going on. However, keep in mind, revving the engine that high without a load on it isn't something I would do too often. It can be hard on the engine.
Dec 25, 2021 at 11:23 AM
