Overhearing
2007 DODGE
150 MILES • 0.6L • V8 • 2WD • AUTOMATIC
PAUL CUDDY 55
  • 6 POSTS
It started running hot. Replaced water pump, thermostat, radiator cap, clutch fan now they found a pin hole in radiator. The water is not circulating and still running hot.
Aug 13, 2016 at 2:38 AM
HMAC300
  • 48,601 POSTS
if there is a hole in radiator that has to be fixed because you wont build pressure in system. after it is fixed if still running hot have system pressure checked for leaks like a head gasket. also, it may need to be bled to get air out of system why you cannot see it moving.
Aug 13, 2016 at 2:46 AM
PAUL CUDDY 55
  • 6 POSTS
Thanks! How do you bleed air from radiator?
Aug 13, 2016 at 4:31 AM
HMAC300
  • 48,601 POSTS
what model dodge and what engine they are all different?
Aug 13, 2016 at 4:44 AM
PAUL CUDDY 55
  • 6 POSTS
It is a 2005 Durango 4.7 engine.
Aug 13, 2016 at 7:41 AM
HMAC300
  • 48,601 POSTS
see picture for instructions. it is pretty easy, also check radiator cap to make sure it is good.
Aug 13, 2016 at 8:29 AM
PAUL CUDDY 55
  • 6 POSTS
Thanks! I have a 1997 Ford Truck. It has a 4.6 when it starts to change gears it loses power, cuts out. I took the gas tank off and cleaned it. It was filthy!
Aug 14, 2016 at 3:56 AM
HMAC300
  • 48,601 POSTS
check your fuel pressure.
Aug 14, 2016 at 4:18 AM
