Coolant squirting from somewhere near my overflow reservoir.
Jan 24, 2017 at 11:06 AM
✓Experienced Mechanic
You may have a split coolant hose or a crack in the surge tank, get a cooling system pressure test done. this is a controlled method of checking for external coolant leaks, the test can be done very quickly often as you wait.
