Coolant squirting from somewhere near my overflow reservoir.
Jan 24, 2017 at 7:06 PM
✓ASE Certified Mechanic
You may have a split coolant hose or a crack in the surge tank, get a cooling system pressure test done. this is a controlled method of checking for external coolant leaks, the test can be done very quickly often as you wait.
Jan 25, 2017 at 3:10 AM
LORI DURAN2
MEMBER
Jan 25, 2017 at 7:44 PM
