overflow bubbling and leaking
189,000 MILES • 4 CYL • AUTOMATIC
ALCIETTTE
I just bought the car and it is is bubbling from overflow tank but not showing it overheating from thermostat. I drove from Bay to Patterson and some leaked out from over tank.
Nov 5, 2017 at 11:02 PM
CARADIODOC
  • 34,415 POSTS
With so little to go on, the best suspect at this point is a leaking cylinder head gasket. Your mechanic can perform a chemical test at the radiator to verify that. The test only takes a few minutes. It involves drawing air from the radiator, while the engine is running, through a glass cylinder with two chambers filled with a special dark blue liquid. If combustion gases are leaking into the cooling system, the liquid will turn bright yellow.
Nov 6, 2017 at 6:36 AM
  • 55,766 POSTS
Here is the guide CARADIODOC is talking about:
Here is another guide that should help as well:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Cheers, Ken
Nov 6, 2017 at 6:54 AM
