car is very over filled transmission fluid. i am going to drain a liter out. at moment car barely drives is it problem with over filled?
Apr 30, 2019 at 7:33 PM
SCGRANTURISMO
✓Experienced Mechanic
Do you have a question for us?
Thanks,
Alex
2CarPros
Apr 30, 2019 at 9:01 PM
Yes you should never drive a car with an overfull transmission, it will foam the fluid and cause the transmission to burn up. Here is a guide that will help you drain some out and then install the correct amount:
