overfill transmission fluid
26,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
SCOTT SHAW 011
car is very over filled transmission fluid. i am going to drain a liter out. at moment car barely drives is it problem with over filled?
Apr 30, 2019 at 7:33 PM
SCGRANTURISMO
  • 4,897 POSTS
Do you have a question for us?
Thanks,
Alex
2CarPros
Apr 30, 2019 at 9:01 PM
  • 55,691 POSTS
Yes you should never drive a car with an overfull transmission, it will foam the fluid and cause the transmission to burn up. Here is a guide that will help you drain some out and then install the correct amount:
May 1, 2019 at 10:58 AM
