overdrive light flashing can only drive in first or scond gear
180,000 MILES • V6 • 4WD • AUTOMATIC
STEVE LANDOLFI
started the car put it in drive would not move just revved up put it in second gear was able to drive home overdrive light started flashing in the first few minutes of driving overdrive light is now flashing and car will not move in drive only first and second never tried reverse
Jan 10, 2015 at 11:26 PM
CADIEMAN
  • 3,544 POSTS
CK.THE FLUID LEVEL BUT THIS SOUNDS LIKE INTERNAL FAILURE. U WILL NEED TO HAVE A TRANSMISSION SHOP LOOK AT IT.
Jan 10, 2015 at 11:53 PM
STEVE LANDOLFI
really duh that's it frauds I want my money back
Jan 11, 2015 at 12:59 AM
CADIEMAN
  • 3,544 POSTS
THAT CAN BE ARRANGED BUT THE LINKAGE IS CONNECTED BECAUSE THE LOWER GEARS WORK. THEIR IS A PRESSURE PROBLEM DUE TO CLUTCH FAILURE OR A PROBLEM IN THE VALVE BODY. LOW FLUID CAN CAUSE THESE PROBLEMS ALSO. ONLY A TRANNY SHOP CAN PRESSURE TEST THE TRANNY. I'M SORRY I CAN'T LOOK INSIDE YOUR TRANSMISSION OVER THE NET.
Jan 11, 2015 at 2:23 AM
