Overdrive flashes on and off?
289,000 MILES • AUTOMATIC
STEPHSTEPH
Overdrive flashes off. Transmission is slipping.
Jul 30, 2023 at 7:44 PM
  • 55,721 POSTS
It sounds like it needs to be rebuilt. I would check the fluid level first and maybe service the transmission to see if that helps.
Here are a few guides to help us fix the problem:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
and
Also, we should run the codes because you might have a pressure regulating solenoid that is not working.
Check out the images (below). Please let us know how it goes
Jul 31, 2023 at 9:30 AM
