Overdrive
101,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TREVOR BARNARD
When I reach around 40 mph the car slips out of gear if i tap the brake, and when i reach 60 mph it will not shift into a higher gear to keep going. Also, it runs at 4,500 rpm's after 40 mph.
Jan 31, 2019 at 1:02 PM
  • 55,781 POSTS
How is the power of the engine? because it sounds like you have a clogged catalytic converter. Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response. Have you checked the fluid level?
Feb 2, 2019 at 6:24 AM
