Overdrive not working
112,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DTERREL
  • 10 POSTS
What will cause overdrive not to work now that it has gotten cold. Any help?
Nov 27, 2017 at 6:02 AM
KHLOW2008
  • 41,812 POSTS
The overdrive solenoid is electrically controlled and if the solenoid is stuck (which often occurs if O/D OFF is seldom used and you attempt to use it.) it would not allow the OD to work.
Check the OD solenoid operations and its wiring to see what is at fault. It could also be due to a faulty on/off switch.
Nov 28, 2017 at 2:00 PM
