On first 2 or 3 start on colder (40 F) mornings, volts go as high as 19.2 volts and power to dash, radio, power steering is lost. When problem occurs, there is a noise like the starter is staying engaged after the car has started. Sounds like it is coming from area near Under Hood Fuse Box (UHFB) or starter relay. Usually on 3rd or 4th start everything lines out though voltage does go to about 16.5 momentarily before settling out at a steady 14.3 volts. Starts starts normally rest of day though it doesn't often stay below 40 F in south Texas...
One time I had to move vehicle in driveway while volts were high and without power steering, etc. Took a few minutes but it seems like voltage slowly came down and back into normal range as things returned to normal by the time I was done moving the vehicle. Dash and power steering came off and on as voltage moved through a critical value I guess
Have replaced generator (alternator) in response to engine codes that pointed at generator - problem had occurred one time prior to replacing generator after SES and Battery lights came on.
All wiring and grounds have been checked and are in good condition.
Problem is similar to one described on this thread:
http://www.2carpros.com/questions/problem-with-power-loss-when-starting
No final solution is posted - last suggestion seems to be ECM...
Any way to contact shadow104747 to find out his final solution?
Thought ECM only had on/off control to generator? Generator is obviously on, but voltage regulator seems to have a delay in lining out at correct level...
Any suggestions as to what the problem could be?
Thank you
Thank you
Mar 5, 2015 at 9:58 PM
