Still overheating after replacing water pump and gaskets
2010 FORD
500 MILES • 3.7L • V6 • 4WD • AUTOMATIC
FAMOUSO
MEMBER
I changed the water pump and gaskets and it is still overheating.
Oct 12, 2016 at 5:21 AM
HMAC300
✓Experienced Mechanic
if it is overheating then have it pressure checked for a head gasket. if it does immediately after starting car check thermostat. also check radiator for cold spots if you feel any then rad is bad should be same temperature all over and make sure all air is out of system.
