Overheats in warm temperature with A/C on at idle (225) and in slow traffic (210-220). Possible fan clutch?
Jun 8, 2019 at 11:09 AM
JIS001
✓Experienced Mechanic
Those numbers actually look normal? Is the the temperature gauge actually going to the red hot?
Jun 8, 2019 at 3:34 PM
HAGSTER64
MEMBER
No, but shouldn't the fan turn on to bring temperature down?
Jun 8, 2019 at 10:26 PM
JIS001
Not necessarily. The fan will not cause the vehicle to run below 200 degrees. That temp is ideal for optimal performance and emissions control. If there is an issue the temp gauge will climb up to the hot mark and cause drive-ability issues.
Jun 9, 2019 at 2:50 PM
HAGSTER64
MEMBER
It was the fan clutch.replaced it and all is well. Thanks for the response.
Jun 9, 2019 at 2:52 PM
JIS001 is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Jun 12, 2019 at 7:44 AM
