Overheating while accelerating not in idle
116,234 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DANYEL
My SUV started overheating while in drive. It will go all the way up to just before the red line then stops pretty much. It only does this while accelerating. The heat/air will blow hot sometimes and cold some. However, while in park while running the temperature goes back down. I am thinking hose or leak but have not had the chance tonight to look, it just started.
Oct 20, 2018 at 4:11 PM
  • 55,721 POSTS
It sounds like you have a partially blocked radiator or the fan clutch is not working right. Here are guides to help us get started:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/fan-clutch-symptoms
and
https://youtu.be/N_-MLVlBHk8
Cheers, Ken
Oct 22, 2018 at 5:32 AM
