Overheating stalls and no power
130,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
CHRISTOPHER HUGHES
So got a engine swap with the same stock motor and it idles sporadic and will shut off. if you let it it drives the idle is up and down took it to Dodge the said that did not unplugged a spark plug said did not show a misfire. they think its the computer?
Jan 9, 2021 at 9:25 PM
Just to clarify, it was overheating and shutting off so you got an engine swap and now the engine is stalling at times and they think it is a misfire which an ECM will correct?
If this the case, either we are missing part of the story or they didn't do much investigation into the possible causes. Is the check engine light on? If so, what are the codes?
If there is no check engine light then we need to start running through this guide that will help with a stall at idle:
https://www.2carpros.com/articles/stall-at-idle
The primary things we need to check are fuel pressure and for a vacuum leak.
Here are guides that help with this:
Let's run through all this material and go from there. If I am missing something please let us know and we can go from there. Thanks
Jan 10, 2021 at 2:15 AM
