Over heating radiator fans aren't coming on?
135,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
VIPERKING75
  • 58 POSTS
I've got an 04 focus SVT, the radiator fans aren't coming on, ive got power everywhere, but im not getting a ground signal to the relays to turn them on in high or low, relays all test good, fuses are good, and the fans work when power is supplied, the coolant temp sensor was replaced with the thermostat a few months ago, the resistance on the sensor is good and fluctuates normaly with temp changes. There is not a head temp sensor, are there any other sensors that the pcm uses in order to call for the fans to come on? Side note, AC system doesn't work, due to a lack of refrigerant
Feb 26, 2026 at 10:55 AM
  • 55,710 POSTS
This car only has the engine coolant sensor going to the PCM to tell the fans to kick on. So I would use a scanner to see what the PCM thinks the temperature is, this can tell us if the PCM is bad or not. Also, see if there are any trouble codes as well.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Also, double check the electrical connector at the coolant sensor, if you have a bad connection the fans will not come on and you should have a check engine light. Let me know what you find. Ken
Feb 27, 2026 at 12:00 AM
VIPERKING75
  • 58 POSTS
Check engine light only shows an oxygen sensor issue and a bulb out. Vehicle reads temp around 190 when warmed up, I was worried it maybe the pcm just not sending signal, it does show ambient at -40 but I wouldn't image that would have anything to do with the fans
Feb 27, 2026 at 5:40 AM
  • 55,710 POSTS
Yep, it can, so please unplug the ambient air sensor, (MAF sensor) to see if the reading changes and the fan come on when hot, just let the engine idle for a while and read the temperature. Please let me know, Ken
Feb 28, 2026 at 1:37 AM
VIPERKING75
  • 58 POSTS
Not really sure what happened, I forced the high speed relay on with ignition for a day, tested it again today and everything seems to be working correctly now
Feb 28, 2026 at 2:19 PM
  • 55,710 POSTS
Nice! we will take the win, let me know if the problem comes back. Have a good week, Ken
Mar 1, 2026 at 3:04 AM
