Overheating when idling with the A/C on
200,000 MILES • 4.6L • V8 • AUTOMATIC
ROMERODAVID3622
When I'm driving and have my A/C on when I'm idling my car starts to overheat. If I turn off the A/C the temperature goes back down . Put a new thermostat and and a new fan.
Jun 30, 2019 at 6:54 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just a quick question first, have you noticed if the electric fans come on? I remember Ford/Lincoln/Mercury had an issue awhile back with the fan relay/module failing causing the fans to not come on. Hope to hear back from you soon.Hope this helps and thanks for using 2CarPros.
Danny-
Jun 30, 2019 at 11:52 AM
ROMERODAVID3622
Yes, it comes on. I was thinking maybe it could be temperature sensor ?
Jun 30, 2019 at 11:54 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, that is a possibility. I've attached a picture below of what it looks like. It will be located in a coolant passage.I'll look for a location picture.Thanks again for using 2CarPros.
Danny-
Jun 30, 2019 at 2:26 PM
ROMERODAVID3622
Let me know if you find the location. thanks
Jun 30, 2019 at 2:51 PM
DANNY L
  • 5,648 POSTS
Hello again.
Are you sure your Crown Vic is a 2011 model year? I've attached a picture below of a 2001 in case you entered the wrong year. Can you double check the model year and get back to me? Hope this helps and thanks again for using 2CarPros.
Danny-
Jul 1, 2019 at 10:31 AM
ROMERODAVID3622
Yes it a 2011 that is the last year they made the Crown Victoria.
Jul 1, 2019 at 10:33 AM
  • 55,816 POSTS
Good here is the location and instructions to replace the coolant sensor. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jul 3, 2019 at 12:44 PM
