Overheating
175,000 MILES
KIMBERLY75
Yes my car just started over heating running at half on my cold to hot. i have a heater and A/C. what could it be? it is also making a noise on the drivers side.
Nov 11, 2017 at 1:12 AM
  • 31,937 POSTS
Check for any coolant loss with a cooling system pressure test. this will help locate any external leaks and you can get a head check done. this is a simple chemical test to check for exhaust gasses in the cooling system. if so you will have a head or gasket problem. If both these are okay, check thermostat, cooling fans, and radiator blockage internally and externally that can restrict air flow. as for the noise, i need more information on this problem at this time.
Nov 11, 2017 at 8:59 AM
