Overheating
122,000 MILES
CHRISTINA VINES
Van is overheating. Replaced radiator cap and added antifreeze.
May 31, 2017 at 3:46 AM
HMAC300
  • 48,601 POSTS
either have a mechanic pressure check for a head gasket problem or rent one at auto parts and pressurize cooling system after it is full. if you see no external leaks and pressure drops then it may be a head gasket problem. there is also a chemical additive you can buy at auto parts to check for a head gasket that changes color either one is good.
May 31, 2017 at 5:06 AM
