Overheating
200 MILES • 1.8L • 4 CYL • AUTOMATIC
SUE SMITH2
We have check all hose, replaced thermostat, water pump, head gasket. heater core was removed due to plugged. so all was bypassed. I believe that has been everything that has been. oh, also we flushed the radiator, due to someone who had car before we owned it had put some kind of stop leak in it and it was built up in side. after doing all this the car is still overheating. can you think of anything to try?
Mar 30, 2019 at 7:57 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Since there was a stop leak placed in the radiator, I question if the block is partially plugged. Have you tried flushing the engine block itself? Also, does it overheat at any speed? Is there evidence other than the gauge that it is overheating?
Mar 30, 2019 at 2:09 PM
SUE SMITH2
On my question u ask for mileage on the Honda Civic LX it not 200 miles , the mileage is 200, thousand . Thank u for any help .
Apr 1, 2019 at 2:53 AM
  • 110,248 POSTS
I would recommend flushing the engine block. Here is a link that will help:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Now, when you do it, remove the thermostat and remove both the upper and lower radiator hoses from the radiator. With the thermostat out, you can flush through the block.
If that doesn't help, I suggest checking for a bad head gasket or ignition timing issue.
Here is a link that will explain how to check the head gasket:
Let me know if that helps.
Apr 1, 2019 at 10:22 AM
