Overheating
173,000 MILES • 3.0L • 4 CYL • 2WD • AUTOMATIC
RODNEYCOON
My car overheated on me last night. I changed the thermostat. No change. Now my heater does not work! Is the water pump bad?
Apr 12, 2018 at 4:33 AM
  • 31,937 POSTS
Did you bleed all the air from the cooling system? are the fans coming on? what range is the temperature gauge on the dash showing when hot? is it in the normal range you normally see?
Apr 12, 2018 at 5:42 PM
