Overheating
256,000 MILES • 3.3L • V6 • 4WD • MANUAL
2002NISSAN2002
Coolant leaks into resolver, but does not recirculate back into the radiator. It would just overflow the resolver container. I had change the thermostat and coolant. Problem still persist. What can it be? Do i need new radiator or the water could be bad?
Aug 12, 2019 at 11:16 PM
Good morning,
I would start by replacing the radiator cap. One of the valves in the cap may be bad.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Aug 12, 2019 at 11:50 PM
2002NISSAN2002
I replace new cap and radiator and i still have the same problem. The coolant would drain into the reserve reservoir, but would not drain back into the radiator, and i would have to keep refilling. Any thoughts what else it could be?
Nov 13, 2019 at 2:19 AM
Okay, you need to pressure test the system. The only way the cap will recover the coolant is if the system is in a vacuum. If it has a leak, there is no vacuum.
You can rent a pressure tester at a parts store.
https://www.2carpros.com/articles/radiator-pressure-test
Nov 13, 2019 at 7:41 AM
