Overheating
2010 NISSAN FRONTIER
150,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
CRDENTON2019
I rented a radiator pressure tester and system Does not pressurize at all?
Thank you
Mar 5, 2022 at 6:15 AM
  • 110,244 POSTS
Either the pressure tester is bad, or you have a large leak. When the system is full, is there any evidence of a leak?
Here is a link that explains how to test it. See if there is anything you are missing.
https://www.2carpros.com/articles/radiator-pressure-test
Also, here is another link you may find helpful to locate/repair a leak.
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know exactly what is happening so I can better help. Also, let me know if the system has any coolant in it, and if the pressure tester is fully seating.
Mar 5, 2022 at 1:08 PM
