Overheating
200,000 MILES • 4WD • AUTOMATIC
GIDALIZ
Good afternoon, i have a concern on my car. lately it has been overheating to the point where on the dash it show up a code that says check charging system, but to me it is not the battery because when i open the hood there is a fan on my side (driver) and it doesn't work at all .
Sep 20, 2019 at 2:24 AM
  • 110,248 POSTS
Welcome to 2CarPros.
It could be a few things. When it says check charging system, that is usually an indicator that the alternator has failed. Has the vehicle given you any trouble starting? Anything that indicates an issue with a dead battery?
Here is where we need to start. First, we need to confirm the alternator is working. Here is a link that explains a simple way to check it:
Here are a few links you may find helpful:
___________________________
Next, I need to know if the vehicle is overheating, or at least indicating it is overheating, regardless of where you are driving. For example, does it only overheat in stop and go traffic or does it also do it at highway speeds? Next, have you checked to make sure the coolant is clean and full?
Sep 20, 2019 at 12:41 PM
GIDALIZ
thank you Joe ,
when i turn on the car it doesn't give me any problem at all , but when i put it in drive it does start to hesitate feeling like it is going to turn off. i put coolant about 2 weeks ago and it is still there. i put water in anytime i go out but when i drive any time when the sun is out or it is hot outside after 10 minutes of having it running or stopped at a light it will give me that code and if i don't park it it will turn off like it has twice .
Sep 23, 2019 at 12:57 AM
  • 110,248 POSTS
Welcome back:
If the fans are not turning on when it starts to get hot and you aren't losing coolant, it has to be tied into the fan's not turning on. If I understood correctly, it does it when you drive in the sun, after aprox 10 minutes, and at a stop light or running. I hate to ask this again, but if you are driving 55 mph, does it happen?
I'm asking because if it does it even at 55 mph, the cooling fan isn't the issue. I just need to confirm. By running, do you mean highway speeds?
If it does it at highway speeds, the first things that come to mind are the thermostat isn't opening to allow coolant to flow through the engine or the system needs drained and flushed.
If you could, please let me know. I'm sorry that I didn't fully understand what you meant. Also, please check the tension on the accessory drive belt to make sure it isn't loose. This belt, aka a serpentine belt, can cause the charging light to come on and overheating. If you look at pic 1, it shows the belt. It will be on the left side when you open the hood at the front of the engine.
___________________________________________________
If it is happening at highway speeds, then we need to start by replacing the thermostat and flushing the cooling system.
Here are two links that explain how those things are done. The thermostat replacement is a general overview, but I will provide specific directions below.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
https://www.2carpros.com/articles/how-an-engine-thermostat-works
____________________________________________________
2009 Acura Truck RDX L4-2.3L Turbo
Thermostat Replacement
Vehicle Engine, Cooling and Exhaust Cooling System Thermostat Service and Repair Removal and Replacement Thermostat Replacement
THERMOSTAT REPLACEMENT
1. Drain the engine coolant. See: Coolant > Removal and Replacement
2. Remove the condenser fan shroud. See: Radiator Cooling Fan > Removal and Replacement
3. Remove the lower hose, then remove the thermostat.
4. Install the thermostat with a new O-ring, then install the lower hose.
5. Install the condenser fan shroud. See: Radiator Cooling Fan > Removal and Replacement
6. Refill the radiator with engine coolant, and bleed the air from the cooling system with the heater valve open. See: Coolant > Removal and Replacement
See pic 2
Before you do any work, confirm the belt I mentioned is tight and in good condition. Honestly, when overheating, the charging light usually doesn't come on, so the belt is the one thing that directly ties the two symptoms together. It's a theory at this point.
Also, here is a link that explains how the cooling fans should be working. There are two types. Your vehicle will have the electric type.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Let me know what you find or if you have questions.
Sep 23, 2019 at 12:53 PM
GIDALIZ
thank you , i will be checking on the belt when i go home and at high speeds it gives me no problem at all its when i'm stuck in traffic or driving slow or stopped in a light or just turned on it will start to hesitate make after about a 10 minute drive it will start to heat up and show the code . the coolant will stay intact but the water will consume quickly if outside is hot and when i turn the A/c on as well it makes a noise to so much that i have to turn off the A/C .
Sep 23, 2019 at 11:48 PM
  • 110,248 POSTS
Welcome back:
I'm a bit confused. When you say coolant and water, I am thinking the same thing. What water is consumed?
Sep 24, 2019 at 10:19 AM
GIDALIZ
well, where the coolant goes it has already consumed about 2 gallons of coolant. it consumes fast just like if i put water in it because i have ran out of coolant.
Sep 24, 2019 at 11:46 PM
  • 110,248 POSTS
Welcome back:
That isn't good. Either we have a leak or a bad headgasket. When this happens, is there excessive white smoke from the exhaust? If you check the oil, does it have a creamy substance mixed with it?
Take a look through these links and follow them to check for what can be causing the issue.
https://www.2carpros.com/articles/coolant-leak-symptoms
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know what you find.
Sep 25, 2019 at 10:45 AM
