Over heat
164,000 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
NABILALMASRI
  • 16 POSTS
my car temperature gauge goes up when stopping at traffic jam
Mar 12, 2016 at 7:27 AM
CJ MEDEVAC
  • 11,000 POSTS
ASSUMING YOUR COOLANT LEVEL IS GOOD.
ARE THE COOLING FANS RUNNING WHEN THE GAUGE IS GOING UP?
YOU CAN CHECK THIS BY DRIVING AROUND THE BLOCK A FEW TIMES THEN LETTING IT RUN IN YOUR DRIVEWAY TO SEE IF THEY ARE RUNNING.
KEEP US POSTED
THE MEDIC
Mar 12, 2016 at 8:27 AM
NABILALMASRI
  • 16 POSTS
yes they are runing
Mar 12, 2016 at 9:15 AM
  • 31,937 POSTS
Checked for blocked radiator, and check sufficient air flow through radiator as well, you may have a blocked core internally or externally, start here.
Mar 12, 2016 at 4:01 PM
