Where is the Output speed sensor located?
250,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TJCASH0069
I have searched all over and I cannot find it. Do I have to take the transmission pan off to find the output speed sensor?
Apr 17, 2023 at 5:47 PM
  • 110,248 POSTS
Are you looking for the turbine input speed sensor or the speedometer speed sensor? If it is the speedo, I attached a pic below showing the sensor's approximate location.
Pic 2 are the directions for replacing it.
Let me know if this helps or if you have other questions. Note that the manual does not refer to an output speed sensor. I suspect it is the speedo speed sensor.
Let me know what you find.
Apr 19, 2023 at 9:55 AM
TJCASH0069
Yes, the speedometer speed sensor.
Apr 19, 2023 at 11:51 AM
TJCASH0069
Is it inside the transmission? I don't see it. I'll take a pic and send the pic back to me with a circle around where it is?
Apr 19, 2023 at 11:55 AM
  • 110,248 POSTS
It should be on the outside of the transmission. If it was internal, the directions would indicate that it needed to be taken apart.
Apr 19, 2023 at 1:36 PM
TJCASH0069
No, it's not there either I've looked everywhere. Do I have to remove something to access it?
Apr 30, 2023 at 3:39 PM
  • 110,248 POSTS
The only other thing I am finding is the input turbine speed sensor. That requires the valve body to be removed. But I just went through another manual and found the same thing for the output.
I attached the directions below for the input sensor. They are vague, but it will give you an idea of the process. It isn't a 10-minute job.
May 1, 2023 at 12:29 PM
