it's a separate part from the pic I sent but you have to drop the pan and it's inside the part called a leadframe behind the valve body. It may be part of the leadframe assembly . however if you are getting a code for that it may not be the problem read the pic that i'm sending if you are experiencing this symptom then it may be from this tsb which the dealer should fix at no cost.
Mar 22, 2016 at 5:19 AM
