Output shaft seal replacement instructions needed
250,000 MILES • 5.0L • V8 • 2WD • MANUAL
JDUB2009
  • 10 POSTS
I got a leak at my rear seal y'all got any instructions/videos on how to replace it?
May 9, 2021 at 3:28 PM
  • 55,694 POSTS
Can you please tell us which seal engine, transmission or differential?
May 11, 2021 at 2:59 AM
JDUB2009
  • 10 POSTS
It's a 1995 Chevrolet Cheyenne 1500 2wd 4 speed manual with overdrive with the 5.0L 305. And it's the output shaft seal on the transmission.
May 11, 2021 at 12:13 PM
  • 55,694 POSTS
you will need to remove the driveshaft. this guide will walk you through the steps with the seal location in the diagrams below. Use a chisel to remove the old seal then install the new seal using a flat steel or seal installer.
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
This video will show you how to install the seal @ 8:05:
https://youtu.be/ytqXLSjHNm0
May 12, 2021 at 4:13 AM
