Outer tire wear loss of stability
2002 BMW X5
234,000 MILES • 6 CYL • 4WD
CHRIS BURGE
  • 21 POSTS
I cannot determine what rear suspension part is causing my car to almost lose control when I hit water or ice. The outside of the tire is really warn. It wants to pull in when it slips and I almost lose control.
Feb 23, 2017 at 8:14 PM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
Do you see excessive wear on just one tire or both on the same axle? Has the suspension system been inspected? The best place for that is at a tire and alignment shop.
Feb 24, 2017 at 6:14 PM
CHRIS BURGE
  • 21 POSTS
Its wear on outer left rear and inner right rear. I had new tires put on and alignment, but the shop never corrected it. Im trying to avoid a bmw dealer. I was wondering how to test for excessive play in rear suspension.
Feb 24, 2017 at 6:27 PM
CARADIODOC
  • 34,309 POSTS
The only way to get wear on the same edges, (left side on both tires), is if "camber" is wrong on both wheels. That is an alignment issue. There's an adjustment on the lateral link, but it affects camber and toe, so you can't change just one without readjusting the other. The link has an eccentric at the outer end, under the shock absorber.
One thing to consider is the lock nut for that eccentric can only be tightened a few times, then it is supposed to be replaced. If that has worked loose, it will allow the alignment to change while you're driving. That can make for a real miserable car to drive.
Feb 24, 2017 at 6:39 PM
CHRIS BURGE
  • 21 POSTS
Ok thanks, I'll keep you informed on what I find.
Feb 24, 2017 at 6:53 PM
