Outer Tie Rod replacement
135,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
KARL NIELSEN
I am replacing the outer tie rod on the driver's side of my vehicle before I take it in and have a professional front end alignment done.
Should I go ahead and replace the passenger side outer tie rod as well?
May 2, 2020 at 8:32 AM
Good evening,
If there is any play in the other side, then yes, replace. There is no need to replace them in pairs.
https://www.2carpros.com/articles/tie-rod-end-replacement
I attached some pictures and the procedure for you to view.
Tools Required
J24319-B Universal Steering Linkage Puller
Removal Procedure
1. Raise and support the vehicle. Refer to Vehicle Lifting.
2. Remove the front wheel
3. Remove the tie rod ball stud nut.
4. Loosen the tie rod jam nut (2).
5. Notice: Do not attempt to free the ball stud by using a pickle fork or wedge type tool, because seal or bushing damage could result. Use the proper tool to separate all ball joints.
Use the J24319-B in order to separate the outer tie rod (1) from the steering knuckle (2).
6. Remove the outer tie rod (3) from the inner tie rod (1).
May 2, 2020 at 9:26 AM
