You have a problem. It may be a little difficult to get the clip on but otherwise, it should slide in and out easily.
Does it go through the new bearing easily?
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle.
Open In New TabZoom/Print
Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
Remove the rear cover and gasket. Refer to Rear Axle Housing Cover and Gasket Replacement.
Remove the pinion shaft locking bolt.
On axles without a locking differential, remove the pinion shaft.
On axles with a locking differential, remove the shaft part way. Rotate the case until the pinion shaft touches the housing.
On axles with a locking differential, use a screwdriver, or a similar tool, in order to enter the differential case and rotate the lock (1) until the lock aligns with the thrust block (2).
Remove the brake drum.
Push the flange of the axle shaft in toward the differential.
Remove the C-lock from the button end of the axle shaft.
Remove the axle shaft from the housing
Images (Click to enlarge)
Dec 28, 2020 at 10:23 PM
