outer heater hoses
1997 PLYMOUTH GRAND VOYAGER
189,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
LINALTICKLES
  • 10 POSTS
hello, i wanted to know if it is possible i could reach the outer lines of the heater core that is running all the way down to the passenger side of the van underneath?
Feb 1, 2018 at 11:15 AM
Good morning,
Yes, they are a pain to replace. you need to remove some thing to get to them especially when installing the new ones. the replacements comes as two in a set and are a challenge to set correctly. they were installed originally without the engine in the van.
Very common failure.
Feb 1, 2018 at 4:27 PM
LINALTICKLES
  • 10 POSTS
Good morning Mr Roy.
Thanks for your reply and you were so helpful yes it is a pain so therefore I have decided to cut off the two places that was damaged and going to replace it with two 58" rubber hoses with four clamps two on each side of the hose. So I am asking now, what are your suggestions on my decision? Would that work?
Feb 1, 2018 at 8:20 PM
yes, that will work but it is temporary. the areas you attach it to are most likely rotted inside as well. keep and eye on it for future leaks. it was a lousy design.
Feb 1, 2018 at 8:23 PM
LINALTICKLES
  • 10 POSTS
Thank you so much Mr Roy you are very helpful.if you have time I had another question about my car. can you check it out please?
Feb 1, 2018 at 8:32 PM
let me check.
Feb 1, 2018 at 8:33 PM
