Car turning over but will not start needing to recharge battery after sitting for a week
149,765 MILES • 6 CYL • 2WD • AUTOMATIC
ARCHPIN
Other than occasionally needing to jump the car runs fine. went to start it and it will turn over but not start. I am charging the battery because it went dead after not using car for a little bit.
Aug 31, 2019 at 7:43 PM
Good morning,
Low voltage is the most common reason for no starts. Your battery needs to be 12.6 volts when fully charged. The starter needs that much power to work and allow the computers to power up there areas.
Can you test the battery with a voltmeter and let me know the voltage?
Aug 31, 2019 at 10:41 PM
ARCHPIN
I ended swapping my fuel pump relay for the horn and it started up. How do I figure out why that happened or just get a new relay for the horn and if it happens again then figure out why? Thank you so much for responding it was very helpful.
Aug 31, 2019 at 11:50 PM
It could be the relay. They do fail.
Replace the horn relay and see what happens.
Let me know if you have continued issues.
Aug 31, 2019 at 11:57 PM
