Orifice tube and expansion valve location
94,400 MILES • 2.5L • 5 CYL • 2WD
CORY2427
  • 293 POSTS
So I need to know where and how to change expansion valve and orifice tube on car. my A/C at times takes forever to get cold and sometimes it be blowing cold then turn warm for a bit then goes back to cold and blows really good. then it’s like it turns the blowing down then picks back up.
Jul 19, 2019 at 12:12 PM
  • 110,248 POSTS
Welcome to 2CarPros.
This vehicle has an expansion valve. It is located on the firewall under the hood. Here are the directions for replacement. The attached pictures correlate with the directions.
________________________
2012 Volkswagen Beetle (5C1) L5-2.5L (CBTA)
Expansion Valve, Removing and Installing
Vehicle Heating and Air Conditioning Expansion Valve Service and Repair Removal and Replacement Expansion Valve, Removing and Installing
EXPANSION VALVE, REMOVING AND INSTALLING
Special tools, testers and auxiliary items required
Torque Wrench 1331 5-50Nm (VAG1331)
A/C Service Station (VAS6007A) (or succeeding model)
Engine Bung Set (VAS6122)
ATTENTION!
Danger due to refrigerant coming out under pressure.
Danger of frost bite to skin and other parts of the body.
Extract the refrigerant and immediately open the refrigerant circuit after that.
If the refrigerant was extracted more than 10 minutes in the past and the refrigerant circuit was not opened, extract the refrigerant again. Pressure in the refrigerant circuit is caused by evaporation.
The expansion valve atomizes the streaming refrigerant and controls the flow rate so that the vapor is gaseous only at the evaporator outlet, depending on the heat transmission.
Refrigerant must be extracted beforehand using the A/C Service Station (VAS6007A) or succeeding model.
Environmentally hazardous draining of refrigerant is an offense punishable by law.
See notes.
Note the safety precautions in vehicles with a start-stop system. Refer to [Vehicles with Start/Stop System General Information ] See: Heating and Air Conditioning > Components > Vehicles with Start/Stop System General Information.
Depending on engine and vehicle version, it may be necessary to loosen or to remove the following components (upper engine cover, compressed air pipe to throttle valve part and, depending on engine, the intake manifold, etc.).
Removing
Perform the Following Work
- Extract the refrigerant with the A/C Service Station (VAS6007A) (or succeeding model) from the refrigerant circuit.
The heat shield is installed in front of the expansion valve, depending on engine.
Loosen, but do not remove, the heat shield and pull it off slightly. The coolant system does not need to be opened.
If Equipped, Loosen the Heat Shield
- Remove nut - 1 - (10 Nm).
- Remove the lock washer - 2 - and the clip - 3 -.
- Loosen the heat shield for the expansion valve - 4 - from the bulkhead.
pic 1
- Remove the bolts - 1 - from the refrigerant line - 2 - (10 Nm).
- Carefully remove the refrigerant lines - 2 - from the expansion valve - 4 -.
- Remove the bolts - 8 - from the expansion valve - 4 - to (5 Nm).
- Carefully remove the expansion valve - 4 - from the heater and A/C unit.
pic 2
Installing
Install the expansion valve in reverse order. Note the following when doing this:
Always replace the O-ring for the high pressure refrigerant line - 3 and 5 -.
Always replace the O-ring for the low pressure refrigerant line - 6 and 7 -.
Lubricate O-ring seal lightly with refrigerant oil before installing.
____________________________________
Jul 19, 2019 at 12:29 PM
STEVE W.
  • 15,381 POSTS
Welcome back. The expansion vale is mounted right at the evaporator core at the firewall. No orifice tube on it. Your issue sounds more like a moisture problem so I would be sure to pull a good vacuum for 45-60 minutes before recharging the system.
Jul 19, 2019 at 12:35 PM
CORY2427
  • 293 POSTS
So should I even replace valve? should I just recover Freon and pull a vacuum so it does not have a accumulator drier or anything? how could I recover system myself would it be better to put fresh Freon in it?
Jul 19, 2019 at 1:19 PM
CORY2427
  • 293 POSTS
I thought that is what the dryer accumulator dryer was for us to remove moisture and stuff.
Jul 19, 2019 at 1:20 PM
STEVE W.
  • 15,381 POSTS
It can remove some, but it is very limited. I would actually start by checking your pressures. Then recover the charge replace the valve (it's cheap and easy to do) and pull a vacuum and be sure it holds, then recharge. Should take 525 grams (18.5 oz) to fill it.
Jul 19, 2019 at 2:54 PM
CORY2427
  • 293 POSTS
Certain way that has to go on? what about o-rings and how can I evacuate Freon if I don’t have a pump to do that ?
Jul 20, 2019 at 3:33 AM
CORY2427
  • 293 POSTS
So how is the car not have a accumulator dryer?
Jul 20, 2019 at 3:49 AM
STEVE W.
  • 15,381 POSTS
The easiest way would be to find a shop that can evacuate the system, then you do the mechanical work and then return to have it recharged. It can be hard to find a shop that will do that but they are out there. Your car has an accumulator drier that's unique. The image is what it looks like. It is attached to the condenser core behind the bumper.
Jul 20, 2019 at 5:28 AM
CORY2427
  • 293 POSTS
How could I just let it out myself and would this be possible cause to?
Jul 20, 2019 at 7:00 AM
CORY2427
  • 293 POSTS
The A/C was engaged and on high, check Freon again it was in the red. let it out until it was in the blue. but went a little cold not much. last time I checked it was perfect not overcharged.
Jul 20, 2019 at 7:02 AM
STEVE W.
  • 15,381 POSTS
You need to use a proper gauge set to see what the low and high side pressures are. Especially if some R134a has been added without checking the pressures.
Jul 20, 2019 at 12:47 PM
CORY2427
  • 293 POSTS
How do I get to and remove the drier tube?
Jul 21, 2019 at 10:07 AM
CORY2427
  • 293 POSTS
I got part just don’t know how to get to it and do it never had to before.
Jul 21, 2019 at 10:08 AM
STEVE W.
  • 15,381 POSTS
The drier is not a fun thing, basically you need to remove the entire nose of the car. However you shouldn't need to replace it, you use a vacuum pump and use it to pull a good vacuum and that will remove the moisture from the system. But you really need to use a good gauge set to check the high and low pressures first.
Jul 22, 2019 at 12:49 AM
CORY2427
  • 293 POSTS
So I need to take bumper off and headlights or just pull radiator out how do you know the drier doesn’t need replaced
Jul 22, 2019 at 10:26 AM
CORY2427
  • 293 POSTS
Don’t it go bad to how come some cars ac drip really good and leave puddles and mine doesn’t
Jul 22, 2019 at 10:27 AM
STEVE W.
  • 15,381 POSTS
Drier has nothing to do with condensate dripping on the ground. It is installed in the system to catch any moisture that could get into the system if there is a leak or someone tries to top off the refrigerant charge without the proper equipment. It is nothing but a tube with desiccant in it. If you recover the charge and then apply a vacuum it will actually boil any moisture out of the system and the drier as well. So far you have decided to replace parts but haven't actually tested the system to see what the issue is. It could simply be low on charge or contaminated if someone tried sealer or similar on it. You really need to use an actual gauge set first.
Jul 22, 2019 at 1:14 PM
CORY2427
  • 293 POSTS
Changed expansion valve did a vacuum and it was perfect recharge ac was cold but still goes to warm and back to cold at times
Jul 24, 2019 at 3:16 AM
CORY2427
  • 293 POSTS
Also still doing the thing where it's like you switched from recirculating to ac back what could these situations be could it be the ac recirculate actuator
Jul 24, 2019 at 9:36 AM
STEVE W.
  • 15,381 POSTS
It could be the actuator(s). I assumed you had checked those already before going under the hood. The recirculating actuator can be removed and replaced through the glove box. The control has to be in the fresh air position to be removed and installed. Testing the doors and controller requires a VW bi-directional scan tool both to read any possible codes in the HVAC control head and to test the individual actuators.
Jul 24, 2019 at 2:09 PM
CORY2427
  • 293 POSTS
Didn’t check them cause they hardly ever go bad on these cars so it could be that or can be evaporator core wouldn’t think it be that cause vacuum was good
Jul 24, 2019 at 10:26 PM
STEVE W.
  • 15,381 POSTS
Hardly ever just means you might be the "lucky" owner.
Jul 25, 2019 at 5:49 AM
CORY2427
  • 293 POSTS
What would be you most guess one of them or evaporator core bad or freezing idk what else to do thev pulled a vacuum it was good and charged it no leaks ac fan works so does radiator fan
Jul 25, 2019 at 6:35 AM
STEVE W.
  • 15,381 POSTS
I would use a scan tool and test the actuators. I highly doubt it's any of the cores, if they were blocked the issue wouldn't go away.
Jul 25, 2019 at 7:31 AM
CORY2427
  • 293 POSTS
I don’t have a scanner for that closest one would be 100 miles away what would be you other guess if it’s not cores or condenser or fan what other thing would make it go cd to hot and kick in and out at times
Jul 25, 2019 at 8:00 AM
STEVE W.
  • 15,381 POSTS
Without a scan tool to test you could replace every part of the system and still not have it work. Sorry but that is a fact. At the moment it could be the temperature control doors, the fresh air door, the body control module, the temperature sensors or the main control head. The BCM and HVAC controller both are units that have to be programmed, The actuators also need a scan tool to reset them to the base positions if they are replaced.
Jul 25, 2019 at 8:08 AM
CORY2427
  • 293 POSTS
What scan tool do I need
Jul 25, 2019 at 8:23 AM
STEVE W.
  • 15,381 POSTS
There are a few that cover the VW/Audi Group vehicles, but those cars can be touchy when it comes to what works and what doesn't. There are a lot that can read the codes but many cannot read the odd VW long codes or connect to all the modules. About the best aftermarket unit is from Ross Tech.
Jul 25, 2019 at 3:23 PM
