Orange Wrench Light Illuminated?
71,500 MILES • 5.0L • V8 • 2WD • AUTOMATIC
STICKS52
  • 7 POSTS
Orange wrench light came on the dash for about 5 seconds. After that the transmission would not go below 3rd gear and no higher than 5th. Turned truck off and restarted and issue went away. That happened two days in a row. Thanks
Jan 15, 2023 at 12:26 AM
  • 110,248 POSTS
What you described sounds like the vehicle went into what is called limp mode. This happens if the computer recognizes a fault in different items.
The reason it is called limp mode is just that. It is designed to allow you to limp to safety.
I have a question, has the light come back on, or have you continued to have the same issues? If so, I recommend having the can-bus scanned.
CAN stands for controller area network. Basically, the different computers/modules on the truck communicate via a few wires. This type of scan will retrieve diagnostic trouble codes regardless of the module storing them.
Here is a link that explains how it is done:
Let me know if this helps, what you find, or if you have other questions.
Jan 15, 2023 at 11:23 AM
STICKS52
  • 7 POSTS
Thanks for your quick response. I have several codes is just got.
P0316,P0722,U0155,U0253,U0401, and U0452.
Jan 15, 2023 at 10:17 PM
  • 110,248 POSTS
That is quite a list. LOL I have a feeling the problem is the output speed sensor. Actually, it could be the sensor, or a wiring issue related to the circuit.
When I went to code P0722, it directs me to follow the diagnostics related to a P0720.
Let me know if you are comfortable performing this.
joe
Jan 16, 2023 at 8:35 AM
STICKS52
  • 7 POSTS
Thanks, Joe, for the great information. I have an appointment with the Ford dealership on Thursday. Figured I better leave it to the pros. Thanks again.
Jan 16, 2023 at 11:38 PM
  • 110,248 POSTS
You are very welcome. If you have a chance, could you let me know what they find? I'm interested in knowing.
Jan 17, 2023 at 10:00 AM
STICKS52
  • 7 POSTS
I sure will. Thanks again.
Jan 17, 2023 at 10:04 AM
STICKS52
  • 7 POSTS
Dealership tells me it is a connector part # Foal3z-7g276-d. They call it a lead frame but the description on the paperwork has output shaft speed sensor. Same as you told me. Problem is there is a national back order on the part. Can’t get one until March. Thanks again for your help.
Jan 19, 2023 at 6:11 AM
  • 110,248 POSTS
Did they give you any ideas as to when the part would be available? March is hard to believe. Also, I believe you can purchase this part from remanufacturers. Did you try typing in the part number to see if you can get one online?
Jan 19, 2023 at 8:57 AM
STICKS52
  • 7 POSTS
I tried online and found several but when I tried to order the message said back ordered. The only one I could find was eBay and it delivers in March. The dealership said they have 5 vehicles waiting on this same part. Go figure.
Jan 19, 2023 at 9:06 AM
  • 110,248 POSTS
Okay, I was hopeful. LOL Regardless, let me know how things turn out for you or if there is anything I can do to help.
Jan 19, 2023 at 9:09 AM
STICKS52
  • 7 POSTS
Thanks Joe. I have talked to 2 other dealerships and they are having the same issue with these parts.
Jan 19, 2023 at 9:11 AM
