Three and five injector circuit open
214,566 MILES • 2.7L • 5 CYL • TURBO • 2WD • AUTOMATIC
CURTISASRED
  • 6 POSTS
Number three and five injector circuit open. any place to start at?
Apr 7, 2018 at 6:52 AM
Good evening.
Start at the injectors themselves. look for loose or damaged connector or wires.
Apr 7, 2018 at 10:40 AM
CURTISASRED
  • 6 POSTS
Okay, i got the number five injector working, rubber gasket stopped the connector from fully seating. i bought two injectors that are for the 2002-2003, and think they are wrong. I am getting one new injector for number three. i have close to six volts out the plug with the van running.
Apr 8, 2018 at 8:16 AM
They have to seat on them tight. the vibration of the engine can unseat them and not allow the injectors to fire.
Apr 8, 2018 at 8:20 AM
CURTISASRED
  • 6 POSTS
I will keep you up to date when i replace the one injector. thanks for all your input so far.
Apr 8, 2018 at 2:59 PM
no problem, we are here to help.
Apr 8, 2018 at 9:37 PM
CURTISASRED
  • 6 POSTS
Okay, put injector in number three, no change scanner still telling me open circuit, need to know where to start at. Thanks.
Apr 17, 2018 at 1:00 PM
Okay, you need to trace the wiring from the injector back to the ECM. look for damage or harness damage. check the connector at the ECM for any dirty, loose or burned pins.
Apr 17, 2018 at 7:53 PM
CURTISASRED
  • 6 POSTS
Okay, i think i have the problem solved. the injector is pulsing and firing. when i remove the plug on the injector the engine does not change, but on the other four it does. any suggestions? i am replacing the glow plugs now, i forgot to mention the glow plugs were not plugged in at the time of the problem.
Apr 19, 2018 at 2:02 AM
While it is out, do a compression test on the cylinder.
Apr 19, 2018 at 2:04 AM
CURTISASRED
  • 6 POSTS
Okay.
Apr 19, 2018 at 2:10 AM
  • 55,748 POSTS
Here is a guide to show you how:
Cheers, Ken
Apr 21, 2018 at 5:52 AM
