misfiring
77,000 MILES • 1.4L • 4 CYL • FWD • AUTOMATIC
BEAST MURPHYA
My Vita is misfiring due to injector one which is continuosly non-stop spraying in fuel. I have changed the injector, but still not solved.
Help guys!
Jan 9, 2017 at 9:44 AM
  • 31,937 POSTS
Check injection plug with a noid light. if active all the time and not pulsing with the engine running, check continuity of wiring back to the PCM and if that is okay PCM will probably be faulty.
Jan 10, 2017 at 7:47 AM
BEAST MURPHYA
Do you mean what is known as the computer box?
Jan 12, 2017 at 7:26 AM
  • 31,937 POSTS
Yes, PCM (Power Control Module) or otherwise the main computer
Jan 12, 2017 at 9:42 AM
BEAST MURPHYA
I have checked with another pcm for a simillar car but still not solved..
Jan 13, 2017 at 3:34 AM
  • 31,937 POSTS
Have you checked the wiring from sensor to PCM as directed in first post?
Jan 13, 2017 at 6:24 AM
BEAST MURPHYA
Maybe i am mistaking what you are saying..let me ask..pcm and computer box are they the same thing?
Jan 14, 2017 at 6:59 AM
  • 31,937 POSTS
yes,
Jan 15, 2017 at 4:45 AM
