Opel vectra burns oil
160 MILES • 1.6L • 4 CYL • 2WD • MANUAL
MARTINLOFTUS
Thank you for a brilliant site.
Car burns about a litre of oil every 2000 kilometres.
Have an error code 0171.
Idles high on start up otherwise runs fine.
Been going on a while, do not want to inflict
any more on the car.
I am reasonably handy and have done a lot of research, (and looking).
Having a good mechanic doing a diagnostic tonight. (Has just cancelled till next week).
Don't expect an answer from you guys based on above little information.
Really write to say your site, your site is a Godsend.
To think you give such help that I will use,
for free is amazing.
After having a very bad experience with work
a mechanic lately.
Will report back if possible.
Thank you again.
Jan 15, 2016 at 11:53 PM
CJ MEDEVAC
  • 11,000 POSTS
IF YOU HAVE HIGH MILEAGE, YOU MAY BE BURNING THE OIL DUE TO CYLINDER/ RING WEAR.
INSURE YOU ARE NOT LEAKING IT OUT AT A GASKET OR COMPONENT (SUCH AS AN OIL PRESSURE SENDING UNIT)
THIS LINK MIGHT AID YOU IN RIDDING YOUR VEHICLE OF THE PO171 CODE, IT DOES GIVE POSSIBLE SOLUTIONS
http://www.obd-codes.com/p0171
THE MEDIC
Jan 16, 2016 at 12:43 PM
MARTINLOFTUS
Thanks. Am pursuing another mechanic, will report back.
Jan 17, 2016 at 2:17 AM
HMAC300
  • 48,601 POSTS
a litre of oil isn't bad for an aged car the 171 code may be low fuel pressure. However this car is not sold in U.S. so we have no info on it.
Jan 17, 2016 at 4:54 AM
THIS IS MIKE
  • 686 POSTS
Mhpautos
Expert
Jan 18, 2016.
At that rate of oil consumption I would be looking at a ring problem, that much oil being burnt will start to foul a spark plug so you should see grey ash deposits on the electrode, also a wet and dry compression test will be a good tool to see how the rings are performing and a leak down test will also give you a good indication of ring condition as well.
Jan 18, 2016 at 1:02 AM
