2001 Opel Vectra some problem with gear up
50,000 MILES • 4 CYL • FWD • AUTOMATIC
FARHOOD
  • 15 POSTS
rpm does not exceed 5000 rpm consequently the car has not the previous performance in acceleration and speed up.
Jan 1, 2010 at 10:56 PM
DAVE H
  • 13,383 POSTS
have the vehicle plugged into a diagnsotic computer to check for faults stored in the cars computer
Jan 6, 2010 at 9:26 PM
FARHOOD
  • 15 POSTS
[quote:2d85648f47="Dave H"]have the vehicle plugged into a diagnsotic computer to check for faults stored in the cars computer[/quote:2d85648f47]
Jan 8, 2010 at 6:14 PM
FARHOOD
  • 15 POSTS
yes but as its not a tech 3 diagnostic computer in Iran we had to do it by an elder version (tech 2) and so its not done copletely and the problem steel runs. please tell me how i can solve it with an alterntive solution if is has.
regards,
farhood
Jan 27, 2010 at 4:17 PM
DAVE H
  • 13,383 POSTS
even with tech2 .. you should be getting fault codes inducating where the actual fault lies .. please post fault codes ?
Jan 30, 2010 at 9:16 PM
FARHOOD
  • 15 POSTS
first of all thank you for your attention, i m gonna to check the faults again with tech 2 and inform you as soon as get them.
thanks
Jan 31, 2010 at 3:57 PM
FARHOOD
  • 15 POSTS
as i've checked the fualt again with tech 2 to get the erros code i faund out that it can be related to plugs as the computer mentione d missing wires error for all 4 cylindres. it means the replacement spark plugs dosen's suit engine power.
Feb 3, 2010 at 4:30 PM
DAVE H
  • 13,383 POSTS
I would replace the coil pack !
Feb 6, 2010 at 8:04 PM
FARHOOD
  • 15 POSTS
wouldn't be better to replace spark plugs and put a stonger sets instead?
Feb 7, 2010 at 5:39 PM
DAVE H
  • 13,383 POSTS
What is the actual fault codes you are getting ?? .. please post with full codes
Feb 7, 2010 at 7:09 PM
FARHOOD
  • 15 POSTS
we've replaced spark plugs with the main ones but the problem is still running and the rpm doesn's exeed 4500 and diagnostic computer (tech 2) mentions error ; missing fire on all 4 cylindres (1,2,3,4) (but not any error code).
Feb 27, 2010 at 4:39 PM
DAVE H
  • 13,383 POSTS
Replace the crankshaft position sensor ... did you replace the coil ?? or just spark plugs ??
Feb 27, 2010 at 10:39 PM
FARHOOD
  • 15 POSTS
just replaced the plugs and not coil but i cant check the crankshaft sensor it works properly or not could you please help me to check it?
Feb 27, 2010 at 11:18 PM
DAVE H
  • 13,383 POSTS
replace the coil and crankshaft position sensor
Mar 7, 2010 at 8:47 PM
FARHOOD
  • 15 POSTS
i've replaced the coil pack with a new one but position sensor does not match the engine do you have any refrence number or figure of the part?
farhood
Apr 30, 2010 at 11:48 PM
FARHOOD
  • 15 POSTS
we have replaced both coil pack and position sensor but problem still remains and rpm doesn't exeed 4000 could you please help me and tell me what should i do else?
May 4, 2010 at 7:55 PM
DAVE H
  • 13,383 POSTS
have the cars computer reset .. sounds like it is in limp mode !
May 5, 2010 at 9:21 PM
FARHOOD
  • 15 POSTS
how can i reset the computer?
May 7, 2010 at 9:36 PM
DAVE H
  • 13,383 POSTS
use the tech2 to delete the fault codes .. this reset's the computer to it's default settings ready for a drive cycle !
May 8, 2010 at 1:24 PM
