2001 Opel Vectra kickdown problem
45,000 MILES • 4 CYL • FWD • AUTOMATIC
FARHOOD
  • 15 POSTS
When making kickdown and reverse gear for the acceleration to replace gear up again the rpm must far reaches 6000 rpm very fast but it maximum reaches 5,200 rpm so slowly and thus gear up done too late, specially when the gearbox is in sport mode is such that the feet should be removed from the gas pedal to change the gear.
Aug 31, 2009 at 10:04 PM
DAVE H
  • 13,383 POSTS
you will need to have the car plugged into a diagnostic computer to locate the cause of the fault .. possibly the VSS (vehicle speed sensor) is faulty .. or have a transmission repair centre look at the vehicle as the transmission is all electronically controlled
Sep 5, 2009 at 12:03 AM
