2004 Other Opel Models Cylinder number 2 and 3 no spark
2004 OPEL
SANDY009
Engine Performance problem
2004 Other Opel Models 4 cyl Two Wheel Drive Manual
I need help please...
I have opel blazer 4 cylinder. There's no spark at cylinder number 2 and 3. I have replaced coil pack but still no spark. What exactly cause this problem?
Thanks.[img:ef01778559]http://www.2carpros.com/forum/automotive_pictures/342908_12_2_1.jpg[/img:ef01778559]
Apr 11, 2009 at 4:45 AM
DAVE H
  • 13,383 POSTS
you will need to check the CKP (crankshaft position sensor) is sending a correct pulsed signal to the PCM ..remove and clean or replace the CKP ... also check for correct voltage supply from the PCM (computer) to the coil pack !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_493.png
Apr 14, 2009 at 10:07 PM
