1995 Other Opel Models water temperature
1995 OPEL
60,000 MILES • 4 CYL • FWD • MANUAL
JOHN J
The engine runs 10 to degrees too cold and this shows on the gauge and in the heater temperature. The agent has changed themostat and the sensor for the control of the fan. No signs of leaks, no loss of fluid and all pipes and radiator appear normal. Where do I start to localise the problem?
Jun 3, 2008 at 5:34 PM
OPEL PARTS GREECE
  • 131 POSTS
[quote:88575519f6="John J"]Engine Cooling problem
1995 Other Opel Models 4 cyl Front Wheel Drive Manual 60000 miles
The engine runs 10 to degrees too cold and this shows on the gauge and in the heater temperature. The agent has changed themostat and the sensor for the control of the fan. No signs of leaks, no loss of fluid and all pipes and radiator appear normal. Where do I start to localise the problem?[/quote:88575519f6]
What model you have?
What engine type?
What is the problem?
Jun 9, 2008 at 7:23 PM
