1994 Other Opel Models Engine Problems
1994 OPEL
104,000 MILES • 4 CYL • FWD • MANUAL
E SPEAKMAN
Opel, Corsa B. 1994. After cam shaft belt broken and skimming of cylinderhead and damaged valves replaced. On rebuild, Oil light coming on after several miles does not go out again until cold. Oil pump Small piston on O P with spring Stuck. Repaired. Replaced metal seal & refitted. Oil change 10/40's. On start up a lot of white smoke from exhaust but clears when warm. Could the oil pressure switch be faulty?
Nov 25, 2008 at 7:48 AM
DAVE H
  • 13,383 POSTS
replace the switch and the oil temp sensor !!
Feb 25, 2009 at 2:24 PM
