1994 Other Opel Models cooling fan
1994 OPEL
130,000 MILES • 4 CYL • FWD • AUTOMATIC
NATZKI
I owned a 1994 opel vectra 2.0i though it really an old car I don't have enough budget to replace this car so as much as possible i need to restore it in good condition.Actually I have a puzzling problem regarding the cooling fan, it keeps on running even i shut off the engine! I get tired in unplugging the battery connections everytime I park,and plug it again to keep me back on track.Any advice? Thanks.
Jan 15, 2008 at 5:25 PM
CHINI
Well, I'm not an expert neither a mechanic. I have an Opel Corsa 1.4i and I know a little bit about cooling issues because they are pretty common on this model. It seems that your thermostat could have been removed in a mechanical check or maybe it's open and that's why the fan stays running. You should unplug your battery and check your thermostat and replace it if it's broken. It depends on the model you might not be able to this because some of the motor belts can bother you.
I hope it helps, regards
Miguel
Feb 24, 2008 at 4:07 AM
