1993 Opel Omega door locks
OPPDAL OMEGA
Electrical problem
1993 Opel Omega 4 cyl Two Wheel Drive Manual 70 tho miles
passenger door will not unlock,
May 7, 2009 at 6:30 AM
DAVE H
  • 13,383 POSTS
you will need to remove the inner door panel and check/clean or replace the locking mechanism !
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_675.png
May 7, 2009 at 9:42 PM
OPPDAL OMEGA
The problem is the door is locked so how do you take off the panel, if the door will not open?
There must be a way to open the door if the lock will not work either way. How to do this.
May 7, 2009 at 11:19 PM
DAVE H
  • 13,383 POSTS
There is no way of opening the door without removing the inner panel !! it is possible to remove the panel with the door close (not easy, but possible) you will have to get the door panel off i'm afraid !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_678.png
May 7, 2009 at 11:29 PM
