1996 Opel Kadett Motor starts but wont idle.
JONATHANNAIDOO
Engine Mechanical problem
1996 Opel Kadett 4 cyl Front Wheel Drive Manual
I have done the motor on this vehicle and now experince problems in getting this motor to run. I have been through the basics, checked for spark on all 4 cylinders with a timing light, checked ecu signals, checked ecu and jettronic wiring. I suspect air, but where do I start? The pipes appear to be good. Will the car start without the breather pipe from the sump to inlet side of throttle via the cam box?
Apr 28, 2009 at 2:11 AM
DAVE H
  • 13,383 POSTS
thr vehicle should start and run without the PCV hose .. replace it and try again .. also have you checked the timing ...it could be out a little ? also check all vacuum hoses are good and in place !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_604.png
Apr 28, 2009 at 11:17 PM
