1994 Opel Kadett Noise from rockers after valve replacement
1994 OPEL KADETT
185,000 MILES • 4 CYL • FWD • MANUAL
JOHN KASCHULA
I replaced an exhaust and inlet valve on my kadett's head. the tensioner pulley came loose. I only replaced the two pistons which had marks on from the pistons. the rockers for these two pistons were also broken. I replaced the head gasket and all others I removed. I re-lapped the valves as well.
There is a knocking sound from the rockers. I can't be sure if it is any of the valves making this sound. This goes away when the car icles, but becomes louder when the car is revved. I am not sure if any of the hydraulic lifters are faulty or if I simply did not do something wrong when I reassembled the head.
I would really appreciate any advice.
Thanks,
John
Mar 29, 2009 at 11:42 PM
DAVE H
  • 13,384 POSTS
did you have the head pressure tested after replacing the 2 valves and before replacing on the car .. I suspect some other valves may have been damaged in the original tensioner break !!
Apr 1, 2009 at 1:49 PM
